That's awesome, buddy! How was the 60' and what converter and gear is in it?
I was having some oil pressure related issues as well, not as extreme on the low side ( never got below ~37 on the gauge) but I've already found a couple ways to pick it up, in my case it's not a pump delivery issue but a combination of a line side flow restriction combined with too many leaks downstream. The combination of porting the AN fittings going In and out of my oil cooler and inserting a rocker shaft restrictor bushing between the 5/16 shaft stud and the 3/8" bore I the shaft I've picked up the pressure back up another 12-15 Psi without having to go to thicker oil.
I was worried it was the MRL lifters ( since they have pressure fed rollers) but after talking to Mike I figured out where else to look.
Glad your back out there buddy !!
Wise... when you talked to Mike on the lifter
what size hole did that turn out to be... I have
heard .027 on the EDM hole
