I'll have to decide what to do asap since I want to get this thing back together and running this week
I would be surprised if you have the exact same breakage anytime soon. It might not last 300 passes, or something else might give up... But at least you are racing right away.
I wouldn't.........he runs on drag radials. That is the MOST unforgiving tire there is for a race car. Would be better off with slicks from a driveline breakage aspect.
As for the nitrous, you can likely spray it all you want, just don't leave on it, because you are going to break it again nitrous or not
Monte
