I took the whole carburetor apart again, cleaned everything again, lowered the floats a little more, and dropped the fuel pressure down to 5 psi and the car still will not idle. It is still running rich too. It only wants to idle at roughly 1500 rpm. I can sill see gas coming out of the boosters, but I believe the only reason now is because of how high the idle is. I am pretty much at a loss of what to do at this point.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
