Originally Posted By max_maniac
Thanks for the idea's guys up . I have always tried to adjust the throttle cable or just played the stripe at top end with the brakes and think now I will try to use weight. Looks like a box with some bags of lead shot and maybe use the trunk and maybe a box where the back seat would be to help spread some of the weight around.
Russ
If all your trying to do is slow it down why don't you just lower your shift points?
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
