I use an EZ plate restrictor plate system under each carb. i needed to slow down close to 6 tenths. I went to a weight box as well this year to help. In good air I was restricting the car so much that i had no throttle response at the tree. Obviously bad. So this year i have been working on finding middle ground on the plates and using weight to finish me off to the index.
