Well the owners manual for my 68 Barracuda makes no mention of what type of oil goes in the A833 just give capacities. However, the service manual I have states the A833 uses ATF and there is a note: "NOTE: If gear noise or rattle is experienced with the A833, SAE 90 gear oil maybe used in place of the ATF."
I have seen (but don't have a copy) TSBs that basically say the same thing to replace the ATF with gear oil if the customer is complaining of gear noise.
So, yes the factory did put ATF in A833's. Maybe not all years but certainly in some.
