if you get the right cam you may not need such a large squirter. try a brown or blue one
That's what I was thinking, I do have the cam kit
so that will be tomorrow.
I did back the timing down to 35* and it seems to like it
Check your center post in the dist cap(where rotor touches) see if its all goobered up. Or smooth..
I had one that got dimply, changed it and back to normal. something to do with the msd, I'm thinkin.
