Re: Big Ports, Big Flow #s, And Low Duration Camshafts
[Re: Streetwize]
#1727947
01/15/15 03:03 PM
01/15/15 03:03 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Tony,
I think you'll be fine.
Similar to my old 508 combo...Paul ( PHJ426 the guy who bought that motor from me) put a hydraulic flat tappet in place of the 252/258 HR and he's busting new ZL1 Camaros with it. in a 4200 pound 72 roadrunner....and that's with a lot less head than you have on yours.
Just be sure to do some radiusing of mainly the lower 1/2 plenum (Cyls 1-4-6 and 7) to runner transitions in the 440-2d manifold, there's a lot of cfm (and maybe 20hp potential flow) you leave on the table if you don't do it. not really needed with 906 size ports but definitely needed if you're feeding a max wedge.
So are they EZ 295's or the EZ-1's? I would definitely open them (both the heads and the manifold) up to MW if you haven't already, there's only upside to go max wedge at 520 cubes.
I run a 264/268@.050 Bullet HR on my 517 on 108 in at 102 with the Max Wedge Chapmans at 12:1.
Thank Bobby. My heads are the Max wedge CNC 295's from Indy and then given the once over, hand blend as needed and valve job by Dwayne Porter. The intake is the one AndyF used on his dyno mule and is also opened up to max wedge ports. I don't think any additional work was done to it other than port match. Btw, the cam I am running was actually a regrind of a comp cam I had. It was originally a 242/.555 110. Bullet agreed the Comp cam was a bit small, and said the regrind specs would be a better cam for my combination. However they did say I am still leaving a lot on the table...If I really wanted to make the most power possible, I would need a much rowdier solid roller, single plane, dominator, etc. Of course I already knew that.
Bobby, did you ever dyno your Chapman engine? Any chance you have pics of what you did to the intake?
2 kids and a dog
Entire Thread
Street Monkies
01/12/15 06:15 PM
MR_P_BODY
01/12/15 06:20 PM
HotRodDave
01/12/15 07:03 PM
MR_P_BODY
01/12/15 07:07 PM
Street Monkies
01/12/15 07:37 PM
MR_P_BODY
01/12/15 07:45 PM
Hemi_Joel
01/12/15 08:24 PM
ahy
01/13/15 03:15 AM
BradH
01/12/15 08:46 PM
Cogito
01/13/15 12:51 AM
R5P7 Bantam
01/13/15 01:23 AM
GTX MATT
01/13/15 01:37 AM
D-50
01/13/15 02:08 AM
Cogito
01/13/15 06:31 AM
Cogito
01/13/15 06:54 AM
HotRodDave
01/13/15 08:49 PM
Streetwize
01/13/15 10:06 PM
BradH
01/13/15 10:19 PM
goldmember
01/14/15 02:31 AM
Cogito
01/13/15 11:34 PM
Oyvind Mopar
01/14/15 12:45 AM
Street Monkies
01/14/15 01:46 AM
WO23Coronet
01/14/15 01:50 AM
GTX MATT
01/14/15 02:00 AM
BradH
01/14/15 02:05 AM
Street Monkies
01/14/15 02:07 AM
MR_P_BODY
01/14/15 02:23 AM
GTX MATT
01/14/15 03:04 AM
moparmanjames
01/15/15 06:46 PM
BradH
01/15/15 09:15 PM
sixpackgut
01/15/15 09:41 PM
MR_P_BODY
01/15/15 10:04 PM
HotRodDave
01/15/15 10:25 PM
Clanton
01/15/15 10:25 PM
Streetwize
01/15/15 10:25 PM
BradH
01/15/15 11:30 PM
Cogito
01/16/15 04:42 AM
deaks
01/16/15 02:51 AM
GTX MATT
01/16/15 06:43 AM
moparmanjames
01/16/15 07:14 AM
WO23Coronet
01/14/15 02:16 AM
Oyvind Mopar
01/14/15 09:34 AM
gregsdart
01/14/15 03:04 PM
R5P7 Bantam
01/14/15 02:34 AM
MR_P_BODY
01/14/15 02:45 AM
Sport440
01/14/15 03:02 AM
Street Monkies
01/14/15 03:05 AM
R5P7 Bantam
01/14/15 03:25 AM
Dunnuck Racing
01/14/15 03:49 AM
Street Monkies
01/14/15 05:27 AM
BradH
01/14/15 05:19 PM
TonyS451
01/14/15 07:07 PM
67mprfan
01/15/15 03:11 AM
dmking
01/15/15 04:24 AM
TonyS451
01/15/15 05:35 PM
Streetwize
01/15/15 05:59 PM
TonyS451
01/15/15 07:03 PM
Streetwize
01/15/15 07:53 PM
Cogito
01/14/15 07:21 AM
BSB67
01/14/15 03:20 AM
Sport440
01/16/15 04:44 AM
Pacnorthcuda
01/16/15 04:59 AM
moparmanjames
01/15/15 07:01 PM
LaRoy Engines
01/16/15 03:23 AM
goldmember
01/16/15 07:33 AM
BradH
01/16/15 07:47 AM
goldmember
01/16/15 07:54 AM
BradH
01/16/15 01:26 PM
Cogito
01/16/15 08:49 AM
goldmember
01/16/15 09:19 AM
LaRoy Engines
01/16/15 04:17 PM
Clanton
01/16/15 05:33 PM
sublimehemi
01/20/15 08:25 AM
sublimehemi
01/20/15 08:26 AM
Clanton
01/20/15 03:53 PM
sublimehemi
01/20/15 09:05 PM
Clanton
01/20/15 10:02 PM
