thanks now that is what i am looking for. what block was the 572 built around that had main webbing or cap problems? I didn't realize your current combo runs 24 lbs that's pretty stout. And I did take a close look at the block today it gets a little too tight for the 1/2 stud. Once this motor is dialed in though I do want to turn it up and see what it will really make I am hoping it will make north of 30lbs maybe up to 35lbs.
I have 2 engines origionally they were both indy maxx blocks. Now the 572 heads sit on top of a KB block. that is the engine that is in the car now. (30lbs of boost)
Hi Bigtime I was just wondering, what power adder are you using? 30lbs on what size motor?
f-2 procharger / 540
I'd sure like 20lbs on a 557. but i don't think my F1R will get me there
Greg ----------------------------------------------------------------- Cost is irrelevant, making memories is far more valuable!
