Just curious if anyone has put some real boost to an Indy maxx block and your experience? I'm a little worried about the 7/16 head studs clamping power. Or is it possible to convert the block to 1/2 studs and how much of a pain would it be.
I have an Indy maxx block in low deck form with a half fill and I plan to turn the power up with a precision 114 turbo. Maybe 30-35 lbs of boost
I dont have an Indy block. But KB strongly suggests using 1/2 inch studs if your going to throw boost at one of their blocks. I don't believe it's very hard to do. Take it to your motor machinist. They fix threads all the time in blocks. It's not much different. Just more of them
Greg ----------------------------------------------------------------- Cost is irrelevant, making memories is far more valuable!
