My 68 Barracuda was 3412. But with all iron 360/727 including 69-down cast iron water pump, factory brass radiator, 340 hipo ex manifolds, heavy A-body console, 11.75 disks.
Mine did have Toyota front seats, aluminum master cly.
Steve, was that 3412lb scaled weight with you in the drivers seat or empty?
Empty. With 15x8 steel rim spare tire too.
Just prior to putting on the Hotchkis TVS setup. Which should have shed a few pounds. Did not weigh afterwards.
Bouncing the car to get it to settle on scales...
