Quote: The Gen 3 Hemi 427 crate motors are (4.125 bore x 4.00 stroke) all aluminum. Supposedly 100 lbs. less
Lets call it a 426. I dont care if its 1cid bigger... 427 is a Chevy/Ford engine.
190lb blocks? Christ. Things are supposed to get BETTER with technology... not worse. Who thought this one through in the design stages? You can find big block blocks that weigh that if you weigh a few...
