Re: fast 60 ft, slow mph HELP
[Re: sshemi]
#1680630
10/07/14 05:48 PM
10/07/14 05:48 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
My holley black is not enough on my car. About 520 hp 408 4 speed 3.73 3780 lbs. It quits at about 5700 rpms in forth. Stock type pick up but 1/2" to 1/2" alu line to filter then an8 to reg then two an6.
I suspect your issue isn't the fuel pump. I ran a Holley black on my 422 small block for years( 650 ish horse) 9.80's at 3350 pounds at 7300-7500 every pass. Swapped to a much bigger system and saw nothing, zero difference. At 520 horse a blue should even likely be adequate. Could be filter, pickup, voltage, regulator...... But that pump should be plenty adequate
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
Entire Thread
Racebuddy
10/01/14 04:26 PM
Racebuddy
10/01/14 04:30 PM
GTX MATT
10/01/14 04:35 PM
Cab_Burge
10/01/14 05:44 PM
383man
10/01/14 06:45 PM
Sport440
10/02/14 02:38 AM
B3422W5
10/01/14 04:35 PM
MR_P_BODY
10/01/14 04:49 PM
Racebuddy
10/06/14 03:04 PM
Bubba
10/01/14 05:12 PM
FlyFish
10/01/14 08:07 PM
MR_P_BODY
10/01/14 10:07 PM
StealthWedge67
10/01/14 10:22 PM
Cab_Burge
10/01/14 10:47 PM
Thumperdart
10/06/14 05:20 PM
deaks
10/06/14 06:01 PM
67dodge67
10/04/14 06:47 AM
Racebuddy
10/06/14 03:09 PM
CHAPPER
10/06/14 05:17 PM
nss guy
10/02/14 01:32 AM
dvw
10/02/14 02:06 AM
WHITEDART
10/02/14 03:13 AM
W.I.N. Racing
10/02/14 03:40 AM
Thumperdart
10/06/14 06:37 PM
Racebuddy
10/07/14 05:44 PM
sshemi
10/07/14 09:08 PM
deaks
10/07/14 09:22 PM
B3422W5
10/07/14 09:48 PM
sshemi
10/08/14 07:03 AM
deaks
10/07/14 09:56 PM
dvw
10/07/14 11:56 PM
Racebuddy
10/08/14 03:26 PM
deaks
10/09/14 12:19 AM
D-50
10/09/14 01:15 AM
B3422W5
10/09/14 05:29 AM
D-50
10/10/14 01:05 AM
dvw
10/09/14 04:32 AM
moparmanjames
10/09/14 05:08 AM
sshemi
10/08/14 07:06 AM
Racebuddy
10/08/14 03:23 PM
383man
10/08/14 07:18 AM
sshemi
10/08/14 08:53 AM
deaks
10/08/14 10:55 AM
B3422W5
10/08/14 02:11 PM
deaks
10/08/14 02:48 PM
Racebuddy
10/08/14 03:18 PM
sshemi
10/08/14 03:23 PM
sshemi
10/08/14 03:25 PM
