I would lose the notion of running an MP ignition box and go with a ready to run distributor that has the electronics inside it, or use an MSD box and mount it under the dash.
as someone else said you can run the engine wires along the engine and you can run your headlight wiring along the framerail and up to the pivot point of the nose.
