Well being your a BB that helps with the wires in front... you can run your heater hoses down off the housing then jump to the frame to the fire wall... you can also run a smaller heater hose with the electrical wires in it and have it end right near the others on the engine then run to the coil(mounted low) and to the alt.. have the reg mounted on the rad yoke down low... keep all 3 hoses together to look clean
