All the 3rd Gen's have the same rust problem over the rear wheel wells because of the support design. If you can afford newer that is the way I would go. The 4th gen CREW cab back seat has way more room than a 03-08 quad cab. If you get a short box the wheelbase would still make it easy enough to maneuver as a plow truck. I just bought a 12 Mega cab Laramie so I will be selling my 2010 Crew Shortbox Laramie 4x4 diesel, only has 23k on it and gets 21MPG.
Sounds like a nice truck. A 2008 is almost a foot shorter than a 2010 I believe. That would let me park it in the third stall of my attached garage so I wouldn't have to keep it in my shop building. Even a 3rd gen would be tight.
