DO NOT get the Edelbrock 750 with that block and that cam. The Holley 750 is probably fine and the Eddy 800 is great.
If you have a Eddy 750, we can make it work but if you are buying a carb, I would stay away from the 1411. There are plenty of other carbs that are less likely to give you problems.
