The size of the weights on a cast crank 440 converter is the same as those on a cast crank 400 converter so they will interchange.
Some drive slots are larger than others but all are larger than the drive lugs in the pump so that's not the reason it won't go in.
The INTERNET, the MISinformation superhighway
