Quote: My biggest concern would be headers and dry pump location, does anyone make W8 2" headers or bigger that will work with a stock K-frame, motor already has dry pump, pulleys etc just need reservoir, pump is located just under number 1 cylinder
Your on your own with headers... also 1 7/8 should be large enough for that
