head gasket
Head gasket - NOT.
I would suggest a compression test or do a leak down if you have the equipment. Sounds like you have some bad rings or a blown piston. Does the engine missfire.
He says it's running "strong"? It needs a compression test first and then I would look at the PVC system and see it that's hooked up right.
