It's going to be hard to run faster then a 6.50 with your combo of parts. The small cubic inches, low stall, and shallow gears are all fighting against a low ET. I'd change the stall 1st. It will prolly be a better ET gain then a cam. If your stuck on a cam change only I don't think there's a lot to be gained and still keep the lift where you want it.
Can I borrow the blower stuff for a summer?
MMMMMMaybe for 1 race but not the summer. I will get more N/A parts over time be it a vert or cam.I may do a swap at the track from n/a to boost may be fun or the other way.
