Quote: I think I may be able to advance my cam and use it but I don't know.OI have been told it is like an old Super stock cam but like I said I have no idea. .646 int .631 exh at .050 260 int 269 exh at .020 291 int 306 exh int open 21 close at 59 exh open 69 close at 19 112 LSA
Gear? Converter?
Without any more info, my thought is a single pattern around the same intake duration you have now, but tightened up to a 106-107 LSA. Without the blower, the cam you have now is "bleeding out" the mid-range torque you need to get that heavy beast moving.
