Reason why im doing a Gen III hemi. Its the best thing "Mopar" "Fiat" or whatever their flavor of the month has going right now. Not gonna spend 3-4K on a set of BB heads that still flow 20-30cfm shy of what 6.1's will with a $700 port job. There is so much good stuff out there right now from all brands that if you are to stubborn to embrace it, all you will prove is that your old stuff is EXPENSIVE AND SLOW AND HEAVY. So once all you diehards are all done spending $3500 on heads, $1K on lifters and $1-1500 on rockers so the thing will live at 650-800hp how Mopar is it then?
