HI Tig
Thanks for your input, what pressure do you run in your tyres and are they stiff wall hoosiers ?
While we are taliking could you either post the weather conditions from last week or pm them to me. I'm just tyring to get a handle on the car's performance and the conditions, you looked to be about .2 off your pb if i'm not wrong. BTW, I had 13.5 psi n my CO7 Hoosiers.
Mr P
I think you could well be right, certain points can get lost in translation, that's why i ask for clarification sometimes.
If the track conditions are good again, i'm now thinking of tightening the extension at least 4 clicks to 32 from soft to start with and perhaps leave the comp where it was last time.
I realise if the extension is loose the comp needs to be stiff to keep the tyres planted but not sure quite where it needs to be if the ext is tight.
Mick
For now I would leave the compression side where you are
and work on the extension side.. lots of video.. also
get someone to video so the camera is getting a 1/4ing
angle from the rear so you can see the rear and the
front tires and get the camera pretty close(camera
should be just off the quarter panel when your on
the line.. a tripod really helps)
