Right, i've been looking at my settings, on the vid posted, i had the extension set on 24 from full soft out of a possible 40 clicks. On the afco instructions, for heavy door cars slower than 9.90 at the faster end it says 6-8 clicks from full soft, i've moved it to 8 for next time out. On the comp i had 14 clicks from full soft out of a possible 24. Afco says for 12-16 from full soft, so i've moved them to 16. So basically, the comp is around the same but i've loosened the ext 8 clicks. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
