Have done a lot of Internet reading about rods today....... Conclusion: both I beam and H beam rods are run in ultra high output stuff. Different manufacturers carry one or the other or both . Going BACK again to MY initial comment, the Scat 4340 I beam is a better rod than the 5140 Eagle SIR rod. The Scats are in the motor I am installing and shouldn't be a factor at the power level I will make. If I thought they were I wouldn't have bought the motor. I ran Eagle H beams( 4340) arrow billet rods, and compstars in previous engines.... All made more power. Is a Scat I beam a trick rod.... No... But it's not because of its I beam design. Manley's top shelf stuff is I beam The Scat rods with an ultralight spinning assy at 6500rpm and at or under 500 horse should be fine
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
