Page 4 of 5 1 2 3 4 5
Re: Scat or Eagle for I beam rods [Re: HotRodDave] #1642449
07/07/14 07:55 PM
07/07/14 07:55 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I don't think anyone is saying the SCAT I beam is stronger than the SCAT H beam. What we are saying is the SCAT I beam is cheaper and better than re-doing the stock rods witch are very strong, just heavy and not as strong as the SCAT I beam. The eagle I beam is worse than a stock rod, they look like the were made by Burt Monroe in his shed out of old buick parts melted down, only he would have probably made them better than Eagle.
bullcrap I was just told they were stronger.
Re: Scat or Eagle for I beam rods [Re: Quicktree] #1642450
07/07/14 08:06 PM
07/07/14 08:06 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
A lot of back-stepping going on here. Where's that Ricksterhemi guy at. I wouldn't put a procomp distributor in my car let alone their rods.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Scat or Eagle for I beam rods [Re: pittsburghracer] #1642451
07/07/14 08:36 PM
07/07/14 08:36 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I wonder why 440source quit selling their I beem rods.
The 440 Source I beam rods were not made by Scat.
As a general comment,I have a ton of Scat I beam rod motors out there without failure. The Pro Comp rod is a favorite amongst Chevy guys,both big block and small block. The circle track guys beat the crap out of them,way worse than most of the drag and street engines on here ever thought of. They really are a good little rod. They offer 7/16 bolt upgrade,and because of their lite weight,they take a good beating.Carry on.
RIP Monte Smith
Re: Scat or Eagle for I beam rods [Re: CompWedgeEngines] #1642452
07/07/14 08:56 PM
07/07/14 08:56 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Have done a lot of Internet reading about rods today....... Conclusion: both I beam and H beam rods are run in ultra high output stuff. Different manufacturers carry one or the other or both .
Going BACK again to MY initial comment, the Scat 4340 I beam is a better rod than the 5140 Eagle SIR rod.
The Scats are in the motor I am installing and shouldn't be a factor at the power level I will make. If I thought they were I wouldn't have bought the motor.
I ran Eagle H beams( 4340) arrow billet rods, and compstars in previous engines.... All made more power.
Is a Scat I beam a trick rod.... No... But it's not because of its I beam design.
Manley's top shelf stuff is I beam
The Scat rods with an ultralight spinning assy at 6500rpm and at or under 500 horse should be fine
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Scat or Eagle for I beam rods [Re: pittsburghracer] #1642453
07/07/14 09:01 PM
07/07/14 09:01 PM
Lehigh Acres, Florida
rickstershemi Offline
Ricksters right here and he never said or agreed that I-Beams are Strnoger than H-Beams so don't try and say I did.....all I said was that for my build H-Beams weren't needed and I'll stand by that....The Scat I-Beams in my build are hang'n strong as per my engine builders suggestion and if you've never heard of "Mike Thompson Racing Engines" out of Naples....just go to any track in the south and you will most likely find several at any venue
You two might want to look into reading comprehension classes
Not to mention Mike was the National Top Sportsman Champion a cple of years ago in IHRA running his N/A 605 BB Chevy
Rickster
Re: Scat or Eagle for I beam rods [Re: rickstershemi] #1642454
07/07/14 09:05 PM
07/07/14 09:05 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Rickster
ok then please point out what part of this is wrong?
about as hard headed as you let me make myself as clear as I can. AGAIN in high quality parts such as oliver etc the I beam is stronger and the preferred choice. now here we are talking cheap chinese crap like eagle scat etc, imo (this is my opinion nothing more) the H beam is a better rod. ask yourself which one is the cheapest? now why would the I beam be better? I wouldn't give you a plug nickel for a scat or eagle I beam. now you can try to convince yourself they are great rods sense you just bought one if you like I really hope it lasts you a long time and I am wrong.
Re: Scat or Eagle for I beam rods [Re: B3422W5] #1642455
07/07/14 09:09 PM
07/07/14 09:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run Eagle H-beams in all my engines.. BUT as I said
before.. these are OLD H-beams and back when I bought
them they looked great and even measured good.. but
I believe that their quality went down hill in the past
years.. you hear of people breaking lots of Eagle stuff
now days... on my junk those old H-beams have been
to 9600 rpm.. not on a regular basis but its been
more than a few times... I dont know what I would
buy now days but it would be a H-beam.. BUT thats
just me... years ago I also broke a Manley I-beam
but I can break ANYTHING
Re: Scat or Eagle for I beam rods [Re: Quicktree] #1642456
07/07/14 09:16 PM
07/07/14 09:16 PM
Rickster
Hey Einstein.... "basic 340 rebuild" Does this ring a bell
Done here....carry on
Rickster
Re: Scat or Eagle for I beam rods [Re: rickstershemi] #1642457
07/07/14 09:21 PM
07/07/14 09:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you still didn't point out what was wrong, you know why? it wasn't wrong. the H beam is a better rod. and for a $100 bucks one would be crazy not to upgrade.........
now in B3's case they were shooting for as much power as they could so they went with the cheaper lighter rod. I am guessing they were not worried about how long it lasted.
Re: Scat or Eagle for I beam rods [Re: Quicktree] #1642458
07/07/14 09:49 PM
07/07/14 09:49 PM
PA.
"Little"John
"Little"John
PA.
I'm kinda shocked to see some of the guys recommending a known weak link when for a few buck more you can buy a better, stronger H beam rod. But then again that's why I build my own engines and have done so for many many years. I'll do my own research thank-you and when I see failures during my weekly trips to the track that research goes a long, long way. That way I can weed out the show pieces, cruiser, and the "you should see the car I have at home guys"
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Scat or Eagle for I beam rods [Re: pittsburghracer] #1642459
07/07/14 10:29 PM
07/07/14 10:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You know I got to thinking " if SCAT I beam rods break there should be some pics on google". Well after looking through 1000s of pics I can not find a broken SCAT I beam on google. Plenty of busted Eagle SIRs though
Re: Scat or Eagle for I beam rods [Re: HotRodDave] #1642460
07/07/14 10:31 PM
07/07/14 10:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
heck yea, a $300 bullet proof rod. I am in
Re: Scat or Eagle for I beam rods [Re: Quicktree] #1642461
07/07/14 10:55 PM
07/07/14 10:55 PM
Re: Scat or Eagle for I beam rods [Re: FlyFish] #1642462
07/08/14 04:25 AM
07/08/14 04:25 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
H-beams, I-beams...put them together what do you get? HI beams..........thank you, thank you, I'll be here all week.
Re: Scat or Eagle for I beam rods [Re: cudadoug] #1642463
07/08/14 11:07 AM
07/08/14 11:07 AM
Syracuse,NY
Syracuse,NY
I think after reading this, I'm gonna need some JIM BEAM....holy cow.....
RIP Monte Smith
Re: Scat or Eagle for I beam rods [Re: MR_P_BODY] #1642464
07/08/14 11:40 AM
07/08/14 11:40 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I'm in the process if building a 500+ HP 416 and I'm going to use one of SCAT's rotating assemblies. I ordered the forged kit and they use to come with the H beam rods but they now come with the I-beam rods, forged crank and ICON pistons. I did some research and spoke to some Mopar engine builder and they said the I-beams are good rods but over 500hp they would tend to use the H-beams so I sent the first one back and got the kit with H-beams. There wasn't much differance in the price and most of the cost was because Mallory had to be added for the H-beams.
So what I leaned from the builder I spoke to is the if your shooting to 500hp or below for racing or under 600 on the street the I-beams will work just fine. I was told the I-beams are forged and the H-beams are billet rods.
Here are some picture of both SCAT rods.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Scat or Eagle for I beam rods [Re: WadeMetzinger] #1642465
07/08/14 11:41 AM
07/08/14 11:41 AM
Tulsa, Ok
Tulsa, Ok
Pic 2
Re: Scat or Eagle for I beam rods [Re: WadeMetzinger] #1642466
07/08/14 11:42 AM
07/08/14 11:42 AM
Tulsa, Ok
Tulsa, Ok
Pic 3
Re: Scat or Eagle for I beam rods [Re: WadeMetzinger] #1642467
07/08/14 11:43 AM
07/08/14 11:43 AM
Tulsa, Ok
Tulsa, Ok
Pic 4
Re: Scat or Eagle for I beam rods [Re: rickstershemi] #1642468
07/08/14 12:29 PM
07/08/14 12:29 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I think Rickster is on the right track, but I think he needs to calculate the moments of inertia for Iyy in addition to Ixx that he did. I had this discussion with a friend in Tampa about which plane you think has the highest stresses/loads. If the piston is not centered on the rod, then maybe the H-beam looks more attractive? I never did the calculations for a rod, but I ran a similar analysis on a rocker arm design since I think they put the slot in the top (remnants of the Shivy ball stud arrangement) instead of more like the Chrysler forged rocker arms. The top slot did a lot better than I thought it would and actually was slightly better than the I-beam design.
