PS went back and looked at the "numbers", they state a "stiffness" result, shouldn't it be explained/discussed that both those designs have an axis that is stiffer 90 degrees opposite the other by design, and which direction that added stiffness is beneficial and desired, is what makes the choice so varied?
Reality check, that half the population is smarter then 50% of the people and it's a constantly contested fact.
