I made my own from an aluminum water bottle from the 99 cent store. Mounted way up inside right fender and installed hose fitting on bottom and vented up top. No valve. Any fluid that enters, drains back automatically. Don't have to worry bout draining tank or low fluid in trans. I forget it's there and no more leaky vent at the big end.
I made own as well from a part out of an air cond unit. I just clamped a filter on one end to make it look tidy. like yours the fluid is self draining.
