Makes these look the bargin then!
Just get some hubs in 5 on 4 3/4 bolt pattern, redrill your rear axles, and get going!
Or you could replace the rotor hat with a Mustang one...
http://www.wilwood.com/Hats/HatProd.aspx?itemno=170-12624
Rotor...
http://www.wilwood.com/Rotors/RotorProd.aspx?itemno=160-12442
Ironically I priced it out. Buying the hats, rotors, and calipers separately cost more than the entire Mustang kit.
http://www.wilwood.com/brakekits/BrakeKitsProdFront.aspx?itemno=140-12756-CSIC
