I run an srt rotor and viper gen 3 caliper with a bracket Dr diff had at one time. It's a killer setup with a hydroboost and 11.75 rear discs.
I have the same set up in the front. Srt8 rotor = 360mm = 14.17". Rotors are 28 lb each.
And I'm running viper calipers on custom Coleman 14" rotors in the rear. Overkill for the back.
Clearance on GT500 wheels is tight but good (18x9.5 +45).
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
