You can make anything work if you have enough money to throw at it.
One reason I used the 2003-2006 S-class rotors was to get the rotor surface back as far as possible. That gave me more caliper to wheel clearance. They get close to the outside of the wheel but the biggest concern is between the back of the spokes and the side of the brake caliper. Multi-pistion calipers are really w-i-d-e.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
