I have a 5.2 in my 55 Dodge, cant help you with the power steering but the rest I have pretty good sorted
I use a Walbro inline pump but if I do it again I ll go with a in tank pump
I believe the 5.9 needs a fuel pressure regulator , I have heard that there is a GM product that works, fuel regulator/filter from a corvette, if you can use one of those on your car that is...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
