No need to cringe bro
![](/ubbthreads/images/graemlins/smile.gif)
. Dog what is going on with you that the content of my (or anyones) post would be getting under your skin?. What works for me is: to ignore the stuff I dont agree with/apologise when I post something erroneous (which hopefully ain't too often)/try to give helpfull advice wording it as a suggestion rather than a must do/ignore the haters on here unless they jump on me personally. Every post should offer or attempt to offer something constructive so with that in mind here goes: I believe there is ALOT of gain to be had by dialing in the curve dead on with the dist installed cuz every eng is different. If the OP wants a new drop in dist which will be close but not dead on then I'm sure he is capable of making that decision & yes taking the center clip out is a pain but it ain't bad once you get the hang of it. RR
