under normal circumstances, you are right. However, I had an intake gasket leak that didn't show up in smoke, pipes were even light grey. Found the problem when I changed oil and was down a couple of quarts in 500 miles. Fixed with Proformance gaskets, but that made me want to be able to check oil without draining it. Just peace of mind.
