Gregsdart runs the 440-1 heads an make somewhere around 900hp, so I would imagine your combination isn't maxed out. Generally speaking, adding more cubic inches will bring down your peak power RPM as you stated. If all else remains the same, I would imagine the gains would be minimal.
Here's a for you
Alan Jones
