That is a head scratcher.......
When you removed the heads, any indication that a gasket was leaking into the lifter valley?
no, the copper coat on the gasket was rather fresh so it left a nice imprint on the head & the block. i've ruled out a head gasket leak already.
what tests did you do to rule out a head gasket leak?
A pin hole would be very hard to see and may only leak when hot Just wondering.
