.... thousands of pages? get at 'er, it's not like we will use up the internet...seems to me this would be good info to have available.
Welllll.....
consider what was coded, when it was coded during the year and even where something was coded on the tag changed. Then take that times the number of plants in production times three just to cover early, mid and late production then take that times the number of years you want to cover.
Consider you will have to at least discuss the different tag layouts used during those years as context and which plants used them.
You'll have to touch on what SO/VON numbers are and put them in context and discuss which other factors on the tag triggered a certain VON.
You'll have to talk about fonts, screws, rivets and paper clips, bent or unbent, painted or not painted, punches and stamps.
You'll have to find people well versed in each year and plant under consideration and get their input. You'll have to review thousands of original tags from each plant to establish baseline differences then, maybe, find fake tags you can use for comparison.
A 1,000 pages might be a good start to a very boring topic that, in the end, only helps fake tag makers make better fake tags.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
