Most aftermarket carbs come with a Chavy linkage. You would have to purchase an adapter for the carb to get the linkages to line up.
If it is advertised as a Ford carb, then that linkage if for a Ford.
Seldom do the carbs come with a "MoPar " linkage set up.
If I got this right ...
The OE iron intakes use Carter's. Any Edelbrock will bolt on because of the dual bolt holes on each corner of the carb mounting pads. If the Holley does not have this, then it will not bolt on a OE intake. Save certain car/model/engine packages that came with a Holley from the factory.
On your OE small block intake, you can readily bolt on any Edelbrock. Look carefully through the Edelbrock catolog.
