I used poly and I did what and old racer told me to do . Grease it very good and use nylon loc nuts on cam bolts. After you get it aligned just do a couple of spot welds on the cam just to lock em on place but in a easy spot if you need to grind em out . Now loosen up cam bolt just enough to let the arm move free Works like a charm.
