Re: Which is better, flat or dished piston at same comp.?
[Re: jcc]
#1538547
11/23/13 06:41 PM
11/23/13 06:41 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
However a proper chamber shape could also recreate the dish effect you suggest is beneficial, thought I read somewhere less piston surface area, ie flat is more efficient, with all other parameters being optimized. /2
You would have to create more volume somewhere, so reduced quench would be the result. If we are talking about something like a 450 to 470 inch BB, then you have some choices, dish the piston and cut the head, or just run a flat top for pump gas. Once you go past that number of cubes, a dish will be needed anyway. I have 440-1 heads with 62cc chambers. They would need a dish for pump gas on anything bigger than about 420 cubes ,just off the top of my head. But the surface to volume ratio would be better with a dish than a 75 cc chamber and no dish. I suspect the comment about flat tops being better was meant to mean no dome. I fully agree with that, thats why I had the heads cut so far to reach 15/1 compression, very little dome.
Entire Thread
PorkyPig
11/23/13 07:42 AM
Swedcharger67
11/23/13 12:35 PM
gregsdart
11/23/13 02:04 PM
jcc
11/23/13 05:53 PM
gregsdart
11/23/13 10:41 PM
Twostick
11/23/13 10:58 PM
383man
11/23/13 11:25 PM
Swedcharger67
11/24/13 12:14 PM
Twostick
11/24/13 05:50 PM
gregsdart
11/24/13 08:24 PM
Hemi Allstate
11/25/13 12:24 AM
Leon441
11/25/13 01:02 AM
PorkyPig
11/25/13 04:28 PM
383man
11/25/13 07:59 PM
Thumperdart
11/24/13 05:38 PM
