My bet is a piston with the dish...
I'm with you. The distance from plug to furthest edge would be smaller, most likely, and the volume to surface area is better for less timing. Other stuff like not needing small tight valve notches that could potentially shroud the intake valve at overlap would help in a very radical pump gas build.
