interesting analysis
Why thank you
An 800 thunder AVS camoflaged to look like an OE AVS has never been done either....nobody would ever stamp the correct numbers in one, run old rusty choke linkage on one, bead blast it and let it corrode so it looks OE etc, and I would never suggest anyone try such a thing, but it might work I belive the carb rule is just like the head rule....can be interpreted more than one way.
Pump gas isn't going to work either, but again it's all up to interpretation. Race gas can come from a pump, after all.
