Whatever you do, make sure you have quality wire installed. Under no circumstances do you want PVC insulation in your car. Puts off deadly poisonous gases when burns.
You want a true automotive wire with at minimum XLPE insulation. You can get better aircraft wire, but I don't believe it is necessary.
This is what I recommend. Its affordable and a reasonable choice......
