Roe, I was hesitant to do wiring myself. Thing is, I do as much of my own work as possible. I had bad luck with mechanics when I started driving. So I figured if they can do it, so can I, and went to the library. It's easier now as you couldn't take the books out of the library. I soon learned I could save a LOT of money by doing things myself. I have learned a bit from trial and error. Just do one thing at a time and pay attention to what you are doing. Take notes if it helps. The work you have done so far tells me you can do it.
Yeah, Im the same way with mechanical stuff, total confidence there. But the wiring stuff scares me. Im getting a little more confident though, now that you guys who felt the same as me are telling me that you did your own wiring. Maybe I'll order the engine harness and the dash harness and have at it. While the dash is out would be a good time to replace the heater core and blower motor...
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
