This combination is very close to the combo with the big Comp roller cam.
That combo had the .800+ lift cam with an Indy 440-3X intake and wet sump oil pan. This combo has the smaller Jones cam, a Super Victor intake and dry sump. The oil pan was the same one, just ran it dry with the oil tank remote.
Both motors had the same 1.70/1.70 rocker arms, same heads, shortblock, headers, same operating temps, etc.
I also switched from the dyno cell MSD 6 ignition on that big cam test to a MSD 7AL for this test so there could be some power difference there.
Same dyno cell and same limitations. This dyno is limited to about 670 ft-lbs max torque so we're bouncing the needle off the limiter on some of these runs which doesn't make the operator all that happy.
