I just don't consider the curves to be all that reliable so I don't bother to post them. The peak numbers are repeatable so I'm comfortable with them.
One thing I have noticed with this engine is that the Indy claim of 100 hp is fairly valid. I've gone back and forth several times on this shortblock between CNC ported Edelbrock (or MP) heads and the Indy EZ heads. The EZ heads always make about 100 hp more than the std port window heads. It isn't a perfect apples to apples test since the compression drops a point when you switch to the Eddy heads and the rocker arm ratio drops from 1.70 to 1.60, but it is close enough to draw some conclusions.
