Its just my opinion but I dont think the cam is all that big. Bullet made me a custom 251/255 for my stock stroke 360 and the car is heavy with the same compression as the op's. But every time ive had a cam made for a stock stroke combo the cam grinder always told me to advance it..and not one time was it over 104. Op would be doing himself a favor to call the cam company himself and get their opinion.
Hot It really depends on the converter in this case...... Problem when asking the cam company is....are talking to someone who even has a clue... You need to find someone good at specing cams.. You find the people leading in this area are not advancing the cams like was once done.... But in this case, he should advance the cam if all else fails......
