Quote: Got ahold of a degree wheel and checked the ICL twice today and got 107.5 both times. Cam card calls for 106 and I'm already in the 4 degree advanced keyway in my timing set.
Should I buy a new crank key and advance it more?
I would leave the cam.... Is your fuel getting hot from anywhere? Did you check your timing mark on tour damper?
