Quote: Fuel is a 1/2in line return system and the closest it get to any heat source is ~6in away at the mufflers so it shouldn't be getting hot. Ive never checked, but the balancer is new. I'm going to put a decal on it when it goes back together.
I'm starting to think the cam is a little rowdy for the rest of the combo.
That is a big cam......... you will need a real loose converter... is it an 8 inch?
